El_Steak
On 3 separate occasions, all in the last month...
Everything is tightly fitted on my bike so each time its half a day of work to remove the wiring, controller, torque arms and wheel and then put it all back together and try to adjust that damn warped disk brake...
The cause is obvious: lots of potholes, lots of weight on the rear wheel (24s3p of lipo on the rack), hard tail frame and maybe I'm a bit too enthusiastic in my riding. Here's the bike (after 5000km, it's not as shiny anymore):
(motor has been changed after radial fins failure)
This is my main mean of transportation to work for 6-7 months a year. When the bike is down, I have to take the bus. When the rack broke a couple of weeks ago I was stuck in the middle of my commute, had to call my father to come pick me in a minivan and missed an important meeting at work.
So until I can spend months building the nicest full suspension bike with a custom battery box in the frame, I have to find a quick fix solution to shave some weight. I see a few options:
- Go on a diet (I'm at 155lbs so not a lot of room there)
- Slow down to reduce power consumption and scale the batteries down to 24s2p instead of 24s3p (7lbs saved, but its hard not to go fast when your bike can)
- Reconfigure the battery pack to 18s3p (5lbs saved but this would be a pain to configure with my current charging solution)
- Cut the battery pack in half to 12s3p (10lbs saved, but it would be really slow, I guess under 40km/h on my 2807/24" wheel)
- Cut the battery pack in half to 12s3p and swap the motor for a faster winding: 2806 or even 2805 (Might need to go 12s4p with faster winding)
I kind of like the idea of going to 12s as this would both reduce the weight of the battery considerably and force me to slow down. It would also make charging simpler with a single Hyperion 1420i instead of the 2 I use now.
Any other ideas for a quick weight loss?
