Brushless trolling motor?
gobi
I bought a 30 lb minnkota from walmart for $93 today for my little row boat (folding plastic thing called porta bote).
I plan on running it on a little 12v LIFEPO4 battery.
As usual AFTER I bought this trolling motor I peeked at the forum for brushless trolling motor as I was stunned to see that the minnkota was NOT brushless.
Only garmin and lowrance have brushless motors which run around $2k plus,
Really? wow, trolling motor technology is still stuck in the 80s?
Are there any other sources for brushless trolling motors?
duh, I am blind, I see the thread on flipsky
https://endless-sphere.com/forums/viewtopic.php?f=39&t=111246
they have trolling motors and outboards, their outboards are quite well priced,
When you buy a $93 trolling motor from Wal-Mart you are going to get the cheapest thing China can make - which means a brushed motor and a one-FET controller.
true, but the lack of a brushless unit for the "ramen" budget guys was disappointing to say the least.
I have 48v batts and a bunch of 36v batts that I can use to power a 36v or 72v motor,
the insides of endura -
yes, large pot?
https://www.youtube.com/watch?v=htelF-bI2dg
https://www.youtube.com/watch?v=ftLU_NxIjaQ
Let's see for $93 - I need:
24 FET controller
1kw brushless motor
100% money back if I fail to catch fish.
:mrgreen:
yes, large pot?
Definitely not a pot. It's a selector switch so you can choose one of (say) eight different power levels. Each connects a different combination of those conductors.
If you have a 300 watt motor operating at half power, a pot has to drop the other half of that power. That's not something that's going to be inside a plastic housing.
JackFlorey said:
yes, large pot?
I bought a DROK PWM motor controller after I watched this youtube video
the guy just sets the Minnkota to MAX i.e. 5 on the control and uses the PWM to control the motors power inline.
Love it,
The only problem I see is that the DROK PWM controller is NOT waterproof or water resistant and COOLING, I will have to add more cooling.
https://youtu.be/TnpHlmpncJk
I will going to dry run this tonight, I will have to cut off the factor spades and crimp a quick connect.
