azad said:
It seems Lifepo4 100Ah cells can be 2.1kg. Does that not beat the whole purpose of using Lipo then?
https://www.aliexpress.com/item/1005001651192097.html
azad said:
How about these cells?
https://www.aliexpress.com/item/1005001515275916.html
no, because those cells are still junk.
if you are really running a single wheeled trailer you need to change that yo a dual wheeld one. or better: split the battery in 2 and put them on the bike in place of the saddlebags at the rear.
as you are seriously weight and size restricted you need the highest capacity 18650 cells as i mentioned in the calculations i did with the 35E. that is basically your only choice. lifepo4 is simply too big and too heavy to be a reasonable choice in your restricted setup.
the volume of a lifepo pack that size is 37 Liters (aka: ~10 freedoms) versus the 9.5 Liter (aka: 2.5 freedoms
) you need with 18650 cells. its litteraly 4x smaller and 75 freedoms lighter as previously mentioned.
TLDR: 18650 cells are a stupid amount lighter, a bit cheaper and take up a quarter of the size compared to lifepo.
lifepo is clearly not suitable for use on a bike. not unless the only thing you want to drag along is batteries.
lets be clear, i am not against lifepo. i use them all the time. but for application like this its simply the wrong choice.
