Fingle
{deleted thread}
Voltage isn't what makes a motor overheat, it's amperage, or overloading with more current than what the motor can handle. Let's say the motor actually can put out 2000w. Max charge for a 13s would be 54.6v. Check that against your batteries. 2000w/54.6v = a max current draw of 36 amps. You want to do 6p, so 6A current draw per cell. You said you're using Samsung INR 18650, but can you be more specific? Are your individual cells capable of 6A? If not, then the motor won't be the weak link, the cells will be.Initially I thought Id do 13s 6p, but am now worried this will be too high of a voltage as my motor tends to overheat.
That's not a BMS, it's a balance board. It has no overcharge/overdischarge/overcurrent protection. All it does is balance the cells.However I did buy a bms for this project just in case. its a Heltec bms off of aliexpress
( https://www.aliexpress.com/item/100...o.order_list.order_list_main.4.641418022HUrcK)
So, I've got some design sketches I did briefly for school. I needed a reduction of around 1 to 10 for the right angle reducer. This means that the output rpm is lowered enough so it works for connecting to the middle chainring.Biggest problem here:
How do you plan to mount this motor on the bike without causing major weight imbalance or leg/crank interference on one side, given it's shape?
Thanks for the info, Ill send a link for the batteries. These are reclaimed but after testing the individual cells they are all in pretty good condition. (Samsung INR18650-20R 2000mAh - 22A - Reclaimed - 18650 - Li-ion - Rechargeable batteries | NKON)Voltage isn't what makes a motor overheat, it's amperage, or overloading with more current than what the motor can handle. Let's say the motor actually can put out 2000w. Max charge for a 13s would be 54.6v. Check that against your batteries. 2000w/54.6v = a max current draw of 36 amps. You want to do 6p, so 6A current draw per cell. You said you're using Samsung INR 18650, but can you be more specific? Are your individual cells capable of 6A? If not, then the motor won't be the weak link, the cells will be.
And how about the controller? The aliexpress link has a bunch of spec sheets about the various motors, but almost no info about the controller. It says 48v; what's its actual max voltage? That's what you should be looking at in terms of what can handle 13s vs 12s, not the motor.
Not necessarily. There are a lot of intricacies regarding specific use cases, how exactly you'll be using all the components together. But in general, think of it this way: If you need 2000w to go forward, higher voltage = less amps, for the same amount of total power (if the controller can handle it, which is an unknown). That's just ohms law basics.From what I understand if I up the voltage Ill be pushing more amperage through the system.
I always think a BMS is necessary. You don't have to agree with me, there are plenty others on the forum that run systems without a BMS. Be safe.Unless you think that is necessary.
If you want to charge your pack without purchasing more equipment, then yes, you can use your 6s hobby chargers, if you limit your pack to 12s. What's your budget?All I'm looking at for the moment is how I can charge my pack safely and without spending a huge amount on the charger. I have seen some 13s chargers but theyre very expensive.
Yeah thats very true, I'm hoping to use the full potential of the motor as my gearing will need the higher power output. Will definitely go with 13s then, if the controller can manage the voltage. If not as long as there is no damage to the motor ill just replace it.Not necessarily. There are a lot of intricacies regarding specific use cases, how exactly you'll be using all the components together. But in general, think of it this way: If you need 2000w to go forward, higher voltage = less amps, for the same amount of total power (if the controller can handle it, which is an unknown). That's just ohms law basics.
Will definitely get a bms long term, just want to charge the pack for now. Would like to test the system properly.I always think a BMS is necessary. You don't have to agree with me, there are plenty others on the forum that run systems without a BMS. Be safe.
I'm willing to spend a decent amount on a charger, I'd like to do this project safely and take care of my batteries well. The cells were the only truly expensive part of the project. So would like to treat them to a good charger. Probably a budget of up to 100-150 pounds, will likely reuse the charger for future projects.If you want to charge your pack without purchasing more equipment, then yes, you can use your 6s hobby chargers, if you limit your pack to 12s. What's your budget?
Yeah, looked briefly at what amperage I might need for my charger. Looking at around 3-4 amps at 48v ideally. Saw somewhere you should charge with 25 percent of your batteries ah rating. So a charger that could provide around 3 amps would probably be safest for my 12 ah battery.Quick Aliexpress search, this guy can charge your pack in 4.5ish hours and only costs $17usd. That was just the top of the list, there's plenty of other options
I'm building a custom mid drive ebike. Using a 2000watt motor and controller kit off of ali-express. which realistically will only draw around 1500watts.
Sorted most of the motor and drive issues now. Main problem is building the battery, had some Samsung INR batteries already so planning on using those. unsure of whether to use 13s or 12s configuration for my battery. both give fairly similar voltages, running my motor too high could be an issue as my motor tends to overheat. I could either do 13s 6p or 12s 6p, depending on whats better for my e-bike.
Also confused on charging these custom batteries, first time building a high voltage battery pack and I'm not really sure how I should charge it. Usually charge my batteries with this hobby balancing charger, which works well for the lower voltages.
If I did choose to use 12s I was planning on splitting the battery into two 6s packs and charging those individually then having them in series for the ebike. Very difficult to split that 13s for charging. Would rather go with 13s if possible because of the better performance in the end, just unsure whether these motor kits work with 13s
Using this motor kit linked (https://www.aliexpress.com/item/100....order_list.order_list_main.17.21ef1802fklJOF)
Any advice on this pack at all?
Yeah, sorry about that wasn't sure how to delete a thread properly. I didn't include much information in that first post so did another one. Thanks for moving it into this one.Note that the first post of this thread and this reply to it were another thread, instead of being part of this one that discusses the same things that was started later. So my reply below may cover things others already discussed, as I have not (and won't) be reading the rest of the thread--I just moved the OP's post and my reply into this one to keep all the info together.
I've got a screenshot of the motor I chose and its specs. I'm assuming it should run on 13s. Just wanted to see whether I could run it off 12s because then I could split the pack nicely into two 6s batteries. Then wire those in series, just makes charging easier.What exact voltage range is your controller designed for, or what is it's LVC? (the link goes to a page with many options, and doesn't select one).
Alright, thank you, Ill probably go with 13s in this case. As I reckon It would cut out like you said, with the under voltage protection. says that is around 41 v.Most controllers have LVCs for either 13s or 14s. If used with 12s they will shut off the motor from battery voltage below their LVC quite a bit before the battery is near empty.
Yeah little bit worried about their motors, from what I've read they overheat very easily, so thinking about making either a heatsink or doing some sort of water cooling jacket for the motor. Just chose the kit as it wasn't massively expensive and wanted to give this bike design a shot without committing to an expensive motor kit.BTW, "Vevor" as a "brand" hasn't inspired a lot of confidence in some of the threads and posts around here. (they dont' make anything, they just sell (all kinds of) stuff).
Didn't I link a 13s 3A charger in my earlier post?If I cant split the pack, are there any chargers you would recommend that could do around 3 amps at 13s.
No, sorry link didn't work for my location. Said it wasn't available to the Uk. Would like to spend a bit more on the charger though, not sure if id trust any of the really budget ones.Didn't I link a 13s 3A charger in my earlier post?
Yeah Ill give that a go then, see how it works out. Ill post some updates when I've got it together.It'd probably be okay, Aliexpress is a bit of a grab bag
