medusa569
It happens occasionally but I never know when. I run a 42 volt battery on a 9C motor.
The motor wire look to be about 14 gauge...and I currently switched from bullets ( which also burned and eventually melted) to a spade type that allegedly was rated for higher temps. How is it people using higher voltage battery packs aren't complaining about wire /contact melt down and yet I'm getting it. Do i need a thicker wire in the motor, change to a higher temp type wire or use acid based solder? HELP.
