Just Give'r said:
Hi All,
If I wanted to purchase a used ebike that someone has put together, what are my options for checking the battery age/condition?
If the seller allows a 15 minute test ride, for example. Would that be enough time to measure a voltage drop? I am eyeing a cheap 1000w hub 48v bike now.
Thanks in advance.
The "...that someone has put together..." part would scare the crap out of me.
I guess if you could tear the battery down and examine it, and know what you're looking for, that might help. But a battery put together improperly by some rando seems like it would be just waiting to burn down your house. There are nearly infinite ways to put one together wrong...and one way to put everything together right...are connections tight, proper gauge wire used, solder joints good, spot welds good/solid, no wires crossed/pinched/chafing on each other, battery cells properly separated, proper separators used on end caps, no sharp edges, no points of chafing between case/battery, everything heat shrinked/insulated correctly, etc.
If you're OK with that aspect, as far as life, I guess a 15 minute test would do. You could note the battery state of charge, give 'er hell for 15 minutes, and note the state of charge again. If that doesn't seem like 'enough charge' for the money, walk away or negotiate a lower price. The battery may have been abused in the past, but what ever state it is currently in, it will most likely not get drastically worse with good care from here on out.
I guess you may also generate an opinion of the seller... does he seem on the level, bike clean and well maintained, battery doesn't seem to be abused, etc - then that would give a bit of confidence. But if the seller seems shady, bike looks like it was assembled from random parts a few days ago and the battery has hacksaw marks on it from where a lock might have been cut away... again, time to walk!
anyway, my .02
