HighHopes
- Joined
- Mar 28, 2013
- Messages
- 929
there is also a wider picture to consider. as you know, arbitrarily selecting 160kHz switching frequency so that cap is good will leave you with a melting mosfet or hydrogen cooled heatsink to survive. on the good side, if you take the time to find the balance you will find that for all motor drives the results are always reasonable.
what i mean is.. you have 10uF phase current. so what is a good switching frequency? 20kHz? 160kHz? this is a question of control bandwidth for smooth action of the motor. so.. my guess is 100kHz would be in the range of acceptable. i say this because i have 50uh phase at 20kHz which is good, so your 10uH is 5x smaller (faster) so the control bandwidth has to be 5x higher, 100kHz. so i would sayy somewhere between 60kHz & 100kHz would be good for your system (you might calculate to get more accurate). assuming worse case 100kHz.. heck even best case 60khz.. what mosfet can switch at that frequency? how much phase current can you have while staying under thermal limits. when you switch that fast, what deadtime do you need, how will you manage that (100ns might be too much), with higher switching frequency & tighter design limits it becomes far more important to have a good design and absolutely nail perfect the layout & geometry .. are you up fort hat challenge? willing to put in the effort to learn so you design/build correct and minimize lab bench trouble shooting.
so you have to get "in the ball park" with these numbers before you start to calculate the capacitor. think about it.
you don't need to get to my Arms of cap, you need to get to YOUR Arms of cap. that might mean you need 5 parallel caps where i needed just one. the most parallel polypropelete caps i have used is 10, that was for 600V 600A system switching at blazing speeds. that's $500 just in caps + another $150 in snubber.
ps. for the math, use my attached PDF as a guide as it is more accurate. given in previous post in this thread.
