ChrisAPal
- Joined
- May 18, 2020
- Messages
- 3
Hi All: I starting to get lost connecting my cables to the controller/battery and hub. I'm hoping someone with knowledge can do a sanity check on this for me and provide simple instructions on wiring everything up. A simple wiring diagram would be nice but I can't find anything online that I can understand. I've attached pics of my system parts:
350W front hub brushless motor (I don't believe this motor Hall Sensors) it's Hill-Topper hub motor
Thumb Throttle, (I don't want Peddle Assist or Dash Display)
Eahora 36v Ebike Battery
36v Controller
My questions are regarding the Ignition wire from the controller and the thumb throttle connection steps. Can you please answer each question if you know the answers or provide a drawing of the wiring to connect everything together, also feel free to provide a sanity check and/or insight on what I'm doing?
1 - I have tagged all the wires coming out of the controller and have them all figured out to the best of my knowledge, except for how to wire the ignition wire/s and the throttle wires. (see photos). The Ignition has 2 wires (red and yellow) with a jumper. Do I remove the jumper? A step-by-step on how to deal with the ignition wires would be helpful.
2 - I believe the ignition (red) wire goes to the on/off switch/key switch, then from the switch I think I run it to the battery positive and back to the (yellow) ignition wire on the controller. Is this correct?
3 - The throttle has 3 wires coming out of the controller. Where do I connect these 3 speed controller wires and please be specific? I guessing they go to the throttle wires is that right? I haven't received the throttle I ordered yet. Not sure if it has two or three wires.
36v Controller
