Controllers ? vesc?
mrhandy65
Boston mass
I have a scooter right that has a motor that's rated for 2000 w 48 volts. It's a 10-in... I'm using a cheap Chinese controller that says it's 2,000 w and it is an 18 mosfet... The battery I'm using is a lithium ion and it's 16 amp hour and rated for 100 amp... I know that that controller is a complete POS. I paid about $30 for it and it works horribly.. motor is a sensored motor and I'm wondering what controller I should switch to... I've heard a lot of great things about vesc.. I'm wondering if I should switch to a flipski 75200... The 75200 Overkill? Or are there other controllers in that range that are much better? I'm looking for top speed and obviously efficiency something that will give me a good range. I've really only used a lot of the cheap Chinese controllers that I bought off Amazon and eBay, and honestly they've all burnt out very quickly on me, especially if I've modded them in any way... Does anyone have a recommendation on a good controller in that range? Someone told me votol was good for fairly inexpensive price .....
What specifically do you need the system to do for you, under what conditions? Actual numbers (at least guesstimates) are required to provide realistic feedback. Without numbers, I can only suggest that you put your conditions/etc into one or more of the various calculators and simulators out there like the ones at ebikes.ca to see what power levels you *actually need* to do what you want to do under your specific conditions. You may need more power than your existing parts can supply to do what you want.
Some notes:
Range isn't determined by the controller, it's determined by the battery size and your usage under your specific conditions.
Power needed is determined by your specific usage under your specific conditions.
Higher speed takes more power, so you'll get more range by going slower.
Efficiency is unlikely to vary much for any specific controller vs another; it's more about your usage and your conditions vs what the system was designed to do. If it's made to run at a certain speed on the flats, pushing it harder may put it outside the peak efficiency of the parts (but realistically the designers probably placed zero emphasis on efficiency).
Some motors may be more efficient than others, when used within specific usage scenarios and motor RPMs, but most of them dont' have this data (dyno sheets) available so you can't really compare them.
Batteries that say they're capable of really high currents vs their capacity often aren't, really--most of them will have a lot of voltage sag under those loads, so you don't get nearly the power out that you expect, or as high a speed (since hubmotor speeds are affected by the voltage provided), and the cells and interconnects, BMS, etc heat up more than they should. I'd venture that most of them don't really handle more than about twice their capacity rating as amps (also called 2C), regardless of what the sellers claim, and some much less than that.
VESC is probably a good controller type; it's very tunable to various systems. It does require that you tune it for your system parts; it is not a plug-and-play system. I don't know what each specific brand can or can't do, whether it has the features you want, or how good their support is--those are things you'll have to check for each one you're considering buying. As long as you can use VESCTool to set them up, though, you should be able to change any of the settings you need to, and tune them to your motor, battery, etc, as required. And it's opensource so if you know how to code you can alter the software in it to do what you want, assuming the seller adhered to the opensource standard and provided the code, schematics, etc that they used (not everybody does things the way they're supposed to).
Yeah vesc is the beast choice if you want a very tunable controllers. The other choices you listed are good options to, there’s just less adjustment and control. Some of the cheaper controllers the throttle output is more of an on off switch.
Sabvoton is great simple contoller that has good throttle control settings. The Unlocked 200 amp version you don’t need a display and it comes with a reverse and 3 speed connection. I’ve really enjoyed that controller with hub motors. You’ll catch some people that discredit those controllers because they’re not made by the original company. I’ve never had issues, I’ve had two of them.
Lot people go with the fardriver seems to be good controller, but has some bugs and not quite as adjustable as vesc but more than a sabvoton
I know that everybody says that the controllers don't make that big of a difference in speed and range, but I have about four different cheap Chinese controllers and the range and top speed varies so much.... I have an 18 mosfet that I shunt modded that isn't giving me nearly the acceleration or top speed that my 12 mosfet Chinese controller was giving me... The 12 mosfet Chinese controller had a phase of mosfets go out and when I repair them it didn't go so well... But just from seeing how much variation I can get between controllers that are all rated the same? I'm assuming that high-end control is could vary quite a bit too.. is the 75200 over kill? Or does it make more sense than the 75100 overheating on me or is that not something I should worry about if I only plan on running 40 amps?
The price can show you what you've got.
Also speed is depending on the hub motor size so if you mismatch power and size to your controller you get the worst of both
There's something called erpm which can be a limit. Normally a motor will change max speed when you change the battery voltage but advanced controllers also have boost function or timing thingy - what its called? that will drain more power but give you more speed. Like a virtual turn change on the motor.
I imagine these are non-programmable controllers and the reason for the variance is that they have different tunes.
This is why i never buy controllers that can't be programmed. No way are they programmed ideally for whatever i am running.
The esk8 forum has a very extensive write up on the flipsky 75100 and some variations/knockoffs. Pretty good details on updating firmware and issues to watch out for. I believe the aluminum heat sink version 75100 can handle 40 amps but I'd definitely read through that thread a bit before deciding.
Tune-ability is great for Vesc if you have the patience, I'd say it's biggest advantage is power for size followed by ability to data log for troubleshooting. If you are wanting to go through the learning process, those are a fairly inexpensive way to go and stumble through it. If you are just wanting something ready to go out of the package and you can tweak later on, there are a number of private sellers on the Razor Facebook groups that have a pretuned, prewired flipsky option tuned for some motor options. **I have heard they have decent customer service but this would be someone working out of their garage so YMMV
MorbidlyObeseKoala
My friend has this controller and really skates it changing and testing all the settings on it as well as the extra CANBUS or UART whatever protocol it is using to also program buttons and button commands to do things like lights on and turn signals. LOL.
