Skalabala
Hi members
This looks like fun. I like the motor(s) Said to be 3,27kw/kg
[youtube]zI0TNk5gLbU[/youtube]
Skalabala said:Hi members
Two very different "types" of kart.liveforphysics said:I had the pleasure of sharing a pit with an electric kart that appeared to be much lighter, get much better traction, and accelerate much more quickly than the kart in the video (though maybe the kart in the video is just geared tall.)
Regulated Sprint karts, ( most karts up to the 125 cc international class), run 5" dia rims, 8" wide,. 11" OD tyres in the rear.doctorGONZO said:What are the rules about wheel diameter in karts?
riba2233 said:It has headway 38120HP cells. Old, heavy, and expensive.
I dont think they would be suitable.riba2233 said:Still, lifepo4. He should have used some modern 18650 high power cells.
Hillhater said:I dont think they would be suitable.riba2233 said:Still, lifepo4. He should have used some modern 18650 high power cells.
Their pack is capable of 750 amp bursts, and 260volts
so even using 18650's capable of 30 amp burst, it would need a 25p arrangement to provide that power.
and 25p of 18650 weighs more than 3p of those headways !
Best option would be the nanotech lipo.
riba2233 said:those 18650 cells have much stronger bursts, have you seen the Samsung 25r datasheet? 30a is continuous rate, but with some kind of cooling system. Also, agni motor cant take even near 750 a.
Lipo would still be better option, yes.
Skalabala said:Won't 18650 be more expensive and trouble?
Hillhater said:Actually the Samsung data sheet gives the 25R continuous rating as 20Amps,!.. and even at that it hits 95 deg C within a few mins, so yes, a cooling system would be needed. More unnecessary weight that is not realistic on a Kart.
Hillhater said:They claim each of their modified motors will draw 400 amps .
And they have a 600 amp controller
Better think of a really effective cooling system for that pack !
