tylerwatts
- Joined
- Sep 14, 2012
- Messages
- 212
Hello forum.
I have 'outside the box' ideas to problems, usually in the shower/bathroom time. Just showered before bed and had an idea I want to run by you. Please offer constructive feedback if you have experience.
I've been trying to decide the most practical way to build a battery for my oddly shaped space (multi-trapezoidal motorcycle trellis frame) and figuring a 18650 cell would be most flexible. Then the task of welding got me worried and I started looking at kits like Vruzend offer. These are square however and sacrifice some ~12% packaging space utilisation and every little counts.
So my idea was, picturing how an assembly of Vruzend caps linked together makes a big plate, one on top and one on the bottom of a pack (layer). And these now have clamping bolts holding the plates together to lightly compress the cells. And the v1.6 kit is limited to 3.5A per cell, 5A max burst discharge.
Could I make/have made a large PCB with high current traces linking the cell terminals in the correct patters, 1 top PCB and 1 bottom, with soldered in spring terminals for the positive cell ends. Use insulating plastic posts between the cells to stabilise and position them, having a smaller dia pin/dowel shape on each end that fits through a predetermined hole I the PCB and every 5th or so post is threaded and screwed to both PCBs too and bottom to clamp the PCB over the cells.
This would position, clamp and wire the cells all in 1 and could even include BMS circuitry. Potentially a multilayer PCB could be used sandwiched between layers or just separate between pack laters with an insulating rubber sheet or similar. It also significantly reduces the layer height for multilayer batteries giving the highest cell density possible.
I recognise this means bespoke printed PCBs are required but would that be so much more expensive than the Vruzend type kit? The PCBs could be printed in set sizes and configurations with a simple interlocking connector system between them on a layer larger than the individual PCB. And stacking would work the same either way...
Alternatively, the shed builder version is using a thin insulating sheet material such as perspex and attaching terminals through this in a similar manner/design. But more tricky, riskier for faults and not as efficient use of space.
I appreciate your feedback and experience and if anybody knows or has capability to help me build a prototype I'd be keen to discuss this.
Thank you
Cheers
Tyler
Thank you
Cheers
Tyler
