MidniteTweeker
- Joined
- May 16, 2008
- Messages
- 121
Somewhere on this forum I ran across mention of a deadman or e-stop switch. I'm working on my first project now, and It got me wondering if this is something I should include for safety reasons? Thinking about it, there are similar precautions taken on other vehicles. Motorcycles have handlebar mounted kill switches. Motorcycle throttles use pull-pull cables so a stuck throttle does not rely on spring return. Cars have ignition switches. But what does an electric bike do if the throttle malfunctions? Has this ever happened to anyone?
I don't have a controller in hand yet, but I'm wondering about using the brake lever motor cutoff circuit. Initially I did not plan to use this feature, but now am having second thoughts. Even then, as a safety circuit, how reliable is it? Better than nothing, I suppose. But if this were a piece of industrial automation an electronic safety circuit would never fly. Automation wants hard contacts to open, and there needs to be redundant contacts and circuits to guard against contact welding.
Without an e-stop, would could you do with a throttle stuck wide open? Grab the brakes, sure. And then hope you could maintain enough control to hop off and turn the keyswitch on the battery pack? Yikes, this ratchets up the old pucker factor!
Thanks,
MT
Thanks,
MT
