JackFlorey said:
In lithium world there is no study yet about this pulsed charge/discharge
There are tons of studies. Three of the talks I went to at AABC talked about pulse charging regimes.
A quick current pulsed at charge could kick out those dendrite crystals out of tha way.
1) They are not crystals
2) A high voltage gradient (caused by a high current) CAUSES dendrites.
Yes Sir, U are correct, It seems to exist many studies over many years.. but at this moment, maybe 90% of lithium chargers will just put out constant current charging and decrease current until reaches top charge..
The pulsed tech is mostly used for Pb batteries, example "reflex charging"
Google Sources:
A: "what are lithium cell dendrites?"
R: "Lithium dendrites are metallic microstructures that form on the negative electrode during the charging process. Lithium dendrites are formed when extra lithium ions accumulate on the anode surface and cannot be absorbed into the anode in time.24/08/2020"
A: "What is dendrite formation in lithium ion battery?"
R: "Lithium dendrite formation, i.e., a neural-like network of metallic growth that can form at the anode/electrolyte solid/liquid interface during charging, is a main challenge in terms of safety and durability of the Li-ion battery technology, since they can short circuit the battery cell and cause the battery to catch ..."
A: "What is a reflex charge?"
R: "Reflex charging consists of alternating charge and discharge pulses. It is important that the number of cells (11,19,20,22) be identical to the switch setting because the rate and duration of the negative pulses is based upon a full charge voltage of 1.60 times the number of cells for which the switch is set..."
