Miles said:
These would only add 8mm to the crank offset: http://simplybearings.co.uk/shop/p170104/160052RS+Budget+Rubber+Sealed+Deep+Groove+Ball+Bearing+25x47x8mm/product_info.html
Yes, they look like ideal bearing dimensions given the available space within the structural constraints for the required adapter rings. Thanks Miles.
_____________________________________________________________________________________________________________________
John and others, your misinterpreting - to different extents - the issues unique to certain freewheels being integrated into different designs, with differing constraints. Generalisations cannot be so easily made.
Think about the planes of force created by two independent chains connected to adjacent/side-by-side chainrings mounted on the crankshaft/BB spindle via a freewheel (In my case both chainrings are of equal tooth count). When the driving (motor) sprocket and driven (rear cassette cluster) sized sprockets - from the perspective of the chainrings mounted on a common shaft - are of variable but most importantly
different size (variable/differing gear ratios) then the force on driving and driven chains is not equal. This applies a pulling/pushing force on the chain-rings which translates into a lateral twisting force on the bearing/s supporting the twin adjacent chainrings. Twin opposing angular contact bearings - as used by cheapie freewheels - will tolerate loading on all axis. A single deep-groove radial bearing - like in an ENO - is only designed to cope with radial loading - but will take a small amount of force from other axis, but not too much or it will fail quickly. For its intended design, this is fine as it
will support angular loading in a locked state - the only time it should be seeing significant load.
-The Dicta I used failed from torque overload - bearings coped fine. Failure was a result of
some combination of; $#!T metallurgy, too few synchronous engaging pawls, and loading beyond mechanical ability of the structural design - despite the choice/quality of steel used. The same freewheel used at the rear wheel - where they are supposed to be mounted - where torque is
usually significantly less than at the cranks (gearing down the torque/upping the speed), it would likely have handled the reduced torque loading fine.
-The ENO i used failed from inappropriate axis of bearing loading when in an overrunning/freewheeling condition. The problem was exacerbated through the central plane of the single bearing within the freewheel not aligning with the centre distance between the force planes of the two equal tooth count chain-rings adapted to it. If chain-rings of differing size were used, then the best compromise mounting offsets of the two chain-rings would be different as it would affect the force relationship of the two independent chains.
In summary;
-Failure issues with ENOs and other single bearing freewheels
should only be a problem in SERIAL DRIVEN CHAIN-RING scenarios utilising freewheel cranks.
- For PARALLEL DRIVEN scenarios utilising freewheel cranks - such as Miles' Moulton and Matt Shumaker's PK ripper- an ENO or equivalent
should work fine as it is not subjected to significant bearing loading in an over-running/freewheeling state.
- The centreline of the single bearing within an ENO is NOT the centre of the freewheel, it is about one quarter the distance of the freewheel thickness from the lockring side. below shows why.
