Does your room have a window that faces the sunny side? If so, put a piece of metal painted black on both sides in it and it will work better than panel-heater.
Or just let the sun shine straight in, if it will do so long enough to warm up the room any.
Or build a thermosiphon (thermosyphon) system if you have space outside, to move heated water to the inside of the room thru pipes and re-radiate the heat inside, if there's no direct sun path. Would probably move more heat into the room than the panel-heater, at a guess.
