The most readable and convenient display existing on the market. With OSF v20.1C.4 uploaded under tsdz2, which gives you the ability to set all parameters from the display. Built-in USB port for charging the phone. From the display we can read: speed, power put in by the user, power given out by the motor, battery voltage, cadence, motor temperature (if a temp sensor is installed), kilometers traveled, maximum and average speeds from the section, time and much more. You can also have the information displayed in graphs, set thresholds, etc. (NOTE: you also need to upload OSF in the motor controller, we also provide such a service).
The display uses a 5-pin female hermetic HIGO connector for communication (to work properly with the 8-pin TSDZ2 controller, a suitable Conversion 1T4 Wire Harness for TSDZ2 is required)
On the subject of OSF: from the display we can easily and clearly change:
NOTE: OSF is adjusted according to our own experience.
Price - €97.99 / piece
In case of any questions do not hesitate to ask.
More information and products on our store: ebikestuff.eu
We are sending all over the world.
- type of assist (hybrid, eMTB, power, torque, cadence)
- the number of assists (0-9) and to each assist assign our own most corresponding values,
- rendered maximum power,
- calibrate the strain gauge,
- calibrate the voltage,
- set off road/street mode,
- assign keyboard shortcuts (e.g. to quickly change from off road to street mode),
- virtual maneuver, and much more.
