I was casually looking at ebikes after a friend got a 1000w one recently.
I have a pretty decent spec hardtail that I built using a bulletproof nsbikes jump frame a decade ago; I was living near mountains at the time and I didn't want the bounce of full suspension on the way up them; also didn't much care for comfort value I really just wanted to hammer the forks on the way back down. That bike hasn't seen any use for a good while; here's the original parts list:
Fork: Fox 36mm '09 TALAS RC2
Stem: Truvativ Team 1.125 x 75mm (black)
Handlebar: Truvativ Team Riser 31.8 x 680 x 35
Headset: FSA Orbit MX 1.125
Cranks: Truvativ Stylo 3-ring 175mm
Bottom Bracket: Truvativ GXP (included w/Crankset)
Front Brake: Stroker Trail 8"
Rear Brake: Stroker Trail 6"
Tire - Front: Maxxis High Roller 26x2.35 Foldable
Tire - Rear: Maxxis High Roller 26x2.35 Foldable
Tubes: Maxxis Ultralight
Seatpost: Truvativ Team DC x 350mm
Saddle: FL white
Grips: ODI Cross Trainer X
Cassette: SRAM PG980 11-32
Rear Shifter: Sram X9
Front Shifter: Sram X9
Rear Derailleur: Sram X9
Front Derailleur: XT
Chain: KMC z9000
Given that I had most of the push bike type bits I started leaning towards a DIY build; started getting a shopping list together and with every iteration the wattage got a little higher than the 1000w I started at... Eventually settled on 5,000w, got excited, and ordered a motor for £349 here:
https://www.amazon.co.uk/dp/B07ZVP7YL6/ref=cm_sw_r_cp_apa_glt_i_XAT8T434N20QC21K4Q2R?_encoding=UTF8&psc=1
I have since seen the same for less money on Ali... But this way I had the Amazon buyer protection and it did actually show up.
Now that I'm living in relatively flat North Essex, I'm feeling old in my mid 30's, and full suspension comfort seems like a really good idea.
I ordered this frame just because it ticked all my boxes for a bargain price; £190 with an eBay voucher.
https://www.ebay.co.uk/itm/224524021545
Then this DNM shock, £85
https://www.amazon.co.uk/dp/B08R8NYGCT/ref=cm_sw_r_cp_apa_glt_i_FY1YJH7YQFRRVCBF9V7B?_encoding=UTF8&psc=1
30 MOSFET Greentime controller, £123 with delivery and tax:
https://m.aliexpress.com/item/32961621169.html
Found the guy on here selling pretty high spec 20Ah lipo cells for relatively affordable prices, decided to go for 32 of them in pairs so 16 pairs in series, 59.2v-67.2v since the controller has a low voltage cutoff at 40v it wouldn't really want to be any lower voltage.
This 16s BMS has Bluetooth etc and I ordered it for £45
https://www.ebay.co.uk/itm/165030161142
This throttle and voltage display £9:
https://www.ebay.co.uk/itm/353868797445
Charge port, £2.50
https://www.ebay.co.uk/itm/254180444408
Stem mounted holder for an old phone with Bluetooth to BMS:
https://www.ebay.co.uk/itm/275120241619
Then an 8A charger for £85
https://www.ebay.co.uk/itm/255329580844
Have to swap my nice SRAM cassette out for a crappy freewheel, £23
https://www.amazon.co.uk/dp/B09BNFFK2N/ref=cm_sw_r_cp_apa_glt_i_75E6WBAZ3X672WJNF5XP?_encoding=UTF8&psc=1
My wheels had the wrong number of spokes for the motor and they were going to have to be replaced anyway; I did consider small diameter motorbike tyres or fat bike tyres but they didn't really appeal; I'd much rather it looks like a push bike so I don't get pulled over and/or banned from MTB trails etc... so I ordered white powder coated Halo T2's for £90
https://www.halowheels.com/shop/components/rims/t2-26-rim/
Then had to do the front 20mm through axle for the fix forks to match, another tenner.
So the long and the short of it is I'm into it for a grand plus batteries; which is currently a fair bit less than buying a 5000w ebike I think?
Hopefully enough of you read this with enough knowledge and experience to tell me what mistakes I have made so far and which to avoid going forward?
Thanks for reading
Saddle: FL white
Chain: KMC z9000
Charge port, £2.50
Thanks for reading
