Fistful o Volts
Hi there,
i havent posted before but have been reading the forum for several years and gleaned an awful lot. Ive built a few DIY go-karts using re-worked alternators, but now need to buy a hub motor to complete a drift trike for my son (and me). As i havent been able to find the information im after i hope i can get some advice.
The Trike will be front driven with a 20" x 4.0" fat tyre wheel i have (Diametre is 560mm so not far off a 26" MTB)
Drop outs are 135mm so i assume a freewheel rear motor is best
It will be run on smooth mostly flat road surfaces
Weight of trike plus rider ranges from 70 - 110kg
speed up to 35km fine
i have a number of lipo and Li-ion packs that let me run from 36V to 54V but 48V seems a happy medium
I have several ebike controllers (350W, 800W, 1500W plus a VESC) that could be used
I will lace the hub motor myself
It seems to me that i should be looking for decent torque as this will be throttle only, so a geared hub seems best and the lacing easier, but most builds i see use a DD of 1000W plus, so I'm looking for advice on the better option to avoid buying twice. I realize the rear wheels wont last long and we will be changing them out after getting it running, as well as adjusting the seta position and getting some foot pegs on there..
Any advice would be welcome.
Thanks
FfoV
Thanks
FfoV
