Saprix
1 ĀµW
- Joined
- Oct 14, 2022
- Messages
- 2
Hi People out there,
I really need some help and I hope to fine it here
I have dual motor scooter with 4000w motor 15 pair poles,
2 x KLS7230S controllers and 72v battery INR21700 cells with 300A BMS continuous 120A. (Use 60A on each controller).
I wire the controllers according to diagram and also done with angle identification, when switch back on both controllers have green LED.
when I push throttle on one controller everything is fine just little knocking sound from rear motor on 15%-20% throttle.
When I turn on front controller (I have dual/single button bridge pin7 to turn on second motor) and trying to push the throttle in getting really hard noise from the rear motor and itās doesnāt spin freely but front motor is spin ok. i will just mention that rear motor controller is the main controller.
If I turn just rear motor I have no problem as well the front motor, but when Iām trying to use one throttle on both controllers everything going crazy.
I hope you can help me to figure it out cause I donāt know what to do it tried everything.
Just need to find the way to sync Both controllers to Wrok with one throttle.
Thanks a lot
Thanks a lot
