methods said:
I have so much power off the line that I rarely go full throttle for fear of breaking components.
Theres only one thing for it then Methods MOD IT till it wont break hehehe...can't
be Gangsta 8) if your have to be fairy like on the throttle buddy
methods said:
btw: I didnt do anything on your project other than confuse you once and confirm your suspicions the second. You made your own design decisions and they look to have come out great.
hrm maybe so but without your input the controller would still be sitting in the box (or sold) and
the trike would have a 48cc ICE motor in it which would be ashame, i forget after not riding it for awhile how much quicker
it is than my brothers 48cc bicycle, the trike smokes it off the line and is over 20km/hr faster top end LoL..
the range issue we shall usher by without mention hehehe...
methods said:
oh yea. . .
Lets see how you feel when you realize that your range is now half :lol:
All that power tends to go to your head.
If you are like me you will want to burn rubber off of every line to show people how bad-ass your bike is
30 mile range turns into 5 quick
HAHAHA too true...thing is i only really need it to go 5-10km to get to shops/pub and back so if i can cain the hell out of it and still make it there and back im good to go
IF not MORE BATTERIES till i can, one things for certain I WONT be taking it easy I WILL be riding it full throttle everywhere, otherwise its simply no fun, I've had many years of motorcycle riding/racing Methods there are only two speeds flat out and stop
methods said:
How is the motor doing?
Getting hot?
I dunno mate i must have got lucky with the motor from what i have heard from a few, it never gets 'Hot'
luke warm at most after a thrashing up hills...the controller same as yours matey cold when i return. It
is probably a bit overkill for my setup 120amp constant and 200amp peak... i do get up over the 100 amp regularly
off the mark and up the BIGGER hills here but when up and running shes well under 40amp
methods said:
Now. . . That brushed motor is what... 60% efficient?
Imagine how it would feel if you had another 20%
I see brushless in your future. . .
uuuhm...i dont think they are quite that bad are they ? (efficiency wise) up closer to 80%
i think (
someone jump in and correct me if im wrong here) But yes i would have preferred a brushless
setup, i was initially going to buy the Cyclone 1000watt setup but the price put me off
was near 5 times more expensive than what i initially bought, thankfully Safe pointed me in the direction of TNC Scooters when i first joined up here yupz.. im happy with the motor i have now its a star for the price ~120 bucks i paid for it ;-P But yup Methods i also see brushless in the future in the form of a couple of rc motors how boutz one for each wheel hehee (
wouldnt be counting out seeing them in a tig welded ali frame either been in touch with Kerr Engineering regarding having a frame made...just to make 'other Doc' hella jealous hehehe..should be nice to him he's not well is he ..get well soon Doc ) Themz i have experience with used them in my rc helis wont have a problem hooking the ESC up at least LoL.......alternatively the etek is sexy : wink :
I will be playing with the gearing some more i picked up a 9 tooth sprocket for the motor last order from TNC Scooters
i run a 9 tooth now BUT using #25 chain the new sprocket is for a bike chain which opens up the possibility of using a larger
sprocket on the crank, im using max #25 size now 80 tooth i think it is... If i go larger here ill get even more torque, will then make 3 and 4 gear a 'usable' option....not to mention make it even easier to spin the rear tire hehehe...which reminds me i havent heard back from Alan at ChoppersUS i paid for an order last week and havent heard back..i have 3 inch tires )wanted the 4.25 rims and tires to match but they are no longer available Alan tellz me :-( ) 10 extra long brake cables and 20 foot of stainless steel braided brake housing coming ...will have the gears setup and working before long
Me
p.s whats your advice for battery solution Methods? I know you use the Lipo how they working for you? I was set on Lifepo4s until i realized how many amps i pull, they would be useless for me with there 60amp cuttoff... I was tossing up to get some packs from Doc (the Konions) but the idea of 160 cells for a 48v ~17ah pack puts me off that idea HOWEVER the plus is no BMS to worry about ... I like the look of the Headway cells but again the bms puts me off...what would you suggest Mr Methods SIR?
