Cat6
EATON NPR48 POWERWARE PINOUT?
I have an EATON NPR48 POWERWARE RECTIFIER and I am having trouble getting it to power on. I am not sure if it is dead or if it has to be turned on using the EATON controller. There's not much info about it on the net.
If anyone could give me the pinout for pins 1,3,9 on the rear for the AC input I would appreciate it.
If anyone has any knowledge of this rectifier then please advise.
This is a brand new unit so I don't want to write it off yet.
There is 230VAC at the fuses on the main board and 0 VDC static reading (not drifting) on the DC output pins which makes me believe it needs to be switched on using the Eaton controller.
The other EATON NPR48-ES I have power on straight away but they have the flat backplane on the rear the same as the APR48-3G models.
Here is a picture of the rear of the unit.
Thanks
Thanks
