Carguy7555
- Joined
- Nov 17, 2016
- Messages
- 10
Is there a chart that may show how much more efficient say using the exact same amount of 18650 batteries configured into an ever increasing larger voltage pack and how that increases efficiency? We know as the voltage increases there's less resistance through the electrical path. Higher voltage, smaller wires needed to transfer the same amperage. So if I have say 100 18650 batteries and configure the 100 batteries into 48v packs and take the same 100 batteries and configure them into 72v packs. Yes we would have less 72 volt packs compared to the more 48v packs with the 100 batteries. Now you take both packs and run them both at 20mph till both packs hit their low limit (taking into account identical wind conditions, etc). The 72v pack running through the circuitry more efficiently should give you a greater overall ride distance due to the higher voltage efficiency then the less efficient 48v pack. Have there been any % figures posted or chart for this question? If you move from a 48v system to a 72v or 96v system using the same amount of batteries there is a 5% gain? 10% gain? 25% gain? Rich
