El_Steak
I have a 2806 in a 26inch wheel and a Methods 100V/100A controller.
I'm shopping for batteries and am considering a 24s Lipo setup (88volts 50amps).
When I look at the ebikes.ca simulator, this setup produces great torque all the way to high speeds, but a way too high top speed and poor efficiency of 70% at cruising speeds around 30mph.
Using a 2807 or "simulating" a 2809 or 2810 using a trick explained by Justin brings the top speed down a bit and produces better efficiency at lower speeds. It doesn't however improve torque noticeably. (The higher windings = greater torque myth was actually debunked by Justin).
Now this is all at 100% throttle. If I slide it down to 60%, then the top speed and efficiency become perfect for maintaining a 30-35mph speed. Is this accurate? If so, can I assume that simply throttling down to 60% will bring this 4.4kw beast in the sweet efficiency spot when cruising at 30mph on my commute? And yet allow me to burn rubber and reach crazy speeds when going full throttle?
