Tiny finally used the indoor potty tray I made, as she'd held her pee so long she couldn't manage it anymore I guess. Last night when I got home from work she was all antsy like she needed to go so I got her leash and stuff but she then trotted over to the potty tray and squatted on it instead, so I went right over and praised her for it since that's what it's for.
She didn't want to do walkies long enough to go potty after that, at any time, so she didn't go poopy either, after more than a day's holding it, but sometime in the night she finally used the tray for that, too.
She wasn't interested in going out this morning--way too many noises from cars and trucks on 23rd Ave and on Thomas, and she turned right back as soon as she went out the door the first time at predawn, then later she woudln't even go out the door cuz of the noises of remodelling in other apartments in my section. So she used the tray again while I was in the shower, but she missed a little this time. (but that is why I wanted this tile floor, just in case).
We tried again an hour ago (just before midday), but it's so hot that I brought her back in after only a very short walk just within my section of the apartments, in the shady spots.
She's still not eating consistently--sometimes she'll eat everything and lick the bowl clean, but usually she only eats maybe a cup of food total before she's done, and she doesn't go back for more later at all, when I've left the remainder out for her to finish. Doesn't seem to matter which of several flavors and types of wet food I've mixed with water for gravy-flavoring mixed in with the dry food. She should be eating around 2 cups per meal, maybe a little less, at her size and activity level, depending on kind of food, but is only doing about half of that on average, and this is with the food she had already been eating before I got her. (only change is the topping cuz she wouldn't eat at all without it; I'm using less and less of it each time to wean her off it to see how she'll do without it).
Myself, I'm still having bad dreams, but less and less of them. I do still often wake up and feel Tiny there and pet her, thinking "what's wrong with Hachi's fur?" (or Nana's, if Tiny is snoring, cuz Nana did that and Hachi didn't really) before I remember, and am both really sad and a little happy at the same time, which is confusing.
Sometimes I wake up and Tiny isn't in the bed (having gone in to the front room to sleep on the cold tile) and I panic until I realize that's where she's gone, but I still have to get up and look. She doesnt' wake up from little noises as long as the fan and the "marsh sounds" from the clock Bigmoose sent are running, so I don't have to worry about waking her up unless I actually touch her (which will wake her quickly almost always).
I have not had to carry/hold Phideaux (Hachi's toy) since Tiny arrived, but I still carry it in my cargo pod on the bike just in case, for when i'm at work/etc. Still have bad moments here and there, but not often, and nowhere near like before Tiny. I *almost* feel normal again.
On the wifi/etc front: The android phone from Bill will check Gmail via the webmail function just fine, but even copy/pasting the login name and password out of that login window and into the email application will not work--it tells me that one of the two is wrong, even though it's not. So I can't use it for just getting/sending the emails whenever I'm near a hotspot and reading htem offline later, which is what I had planned to do with it.
It also has very little range for it's wifi, so for instance I can't use the DD wifi unless I actually cross the street and go into their parking lot. The McD's wifi I can only access inside the building with it--it doesnt' even see it outside the windows like the laptop does. Staples has a hotspot, too, up in the shopping center I work at, but unless I am either inside or just outside the windows (literally leaning against htem) it won't connect. There *is* an antenna port that uses the same connector the internal antennas on laptops do, so I can dig thru my remaining unmelted laptop parts at the house someday and see if I have a display casing that still has the antenna in it. Then I can put that into something to stick on the back of the phone, and plug into the internal connection to see if that nets me a better signal.
I've thought about lots of signal amplifiers for the laptop, but practically, none of them are really useful because the only unsecured wifi is blocked by buildings that they won't help with. There's lots of secured wifi in unblocked directions, even without amplifiers, so I'd more likely have ot work on doing something with that to be able to get wifi at the apartment itself. :|
