brainzel said:Only for my personal understanding: everything is fixed and I can go on and solder my board to the end, even change the R3 resistor?
Please tell my that it's so simple and everything works fine!
(I can't await to get everything together and charge the first time! )
Yep, make R3 4.7k, make R6, R7, R8 10k and C2 0.1uf and you should be good.
Eric! Nice to see you back. Yes a technical reference is on the to-do list, but I keep making changes to the design so it's hard to keep up.
AndyH has been making and selling fully built boards, so you might check with him. He's also been a great help in the testing process.
I'm presently working on an improved charge control circuit that should eliminate some of the issues with the present design and provide faster charging and wider compatibility with charging sources. Things just aren't moving along as fast as I'd like them to due to being busy with other things.
