An improvement in almost every component!
Just needs Lithium upgrade!
Eco-Ride 2 description
"Item Description
Top of Page
The new
Eco-Ride 2 is the perfect choice for recreational riders. It has a comfortable rider position, which takes all the pressure off your arms, shoulders and derriere. By simply twisting the throttle, it pulls you up hills effortlessly. You'll love how it's upright riding position and power ensures comfortable riding while watching all the miles slip by almost before you notice! Simply put, the Eco-Ride 2 delivers, "all the pleasure of cycling, with none of the pain." The Eco-Ride 2 is equipped with a powerful Currie Electro-Drive system that provides plenty of torque to pull you up a long hill or through a headwind. The battery pack can easily be removed for charging or swapping. It can travel 15-22 miles with normal pedaling or about 10-15 miles with no pedaling at all at speeds of 15+ mph. You can easily double that range by adding an optional second battery pack. If you want to ride a bike and want to do so comfortably, just ride the Eco-Ride 2!
eZip Eco-Ride 2 SLA LSF Electric Bike, Black:
Frame: powerful Currie Electro-Drive system; aluminum 6061, rack, bottle and fender bosses
Forks: alloy cast suspension, fender eyelets
Motor: rear hub mounted 450W
Battery: sealed lead acid 24V10Ah 240Wh
Display LED battery level display
Headset: VP 1-1/8
Top speed: 15 mph/25 kph motor
Range: 15-22 miles/24-35 km with normal pedaling
Shift lever SRAM gripshift
Front derailleur
Rear derailleur: Shimano Altus
Cassette or freewheel Shimano freewheel 14-34T, 7-speed
Chain KMC Z72
Pedals: resin platform with non-slip tread
Hubs: ft/rear alloy with w/QR front
Rim alloy 7X
Spokes: stainless
Tires: Innova siped design, 26x2.0
Brakes: alloy linear pull
Brake lever: alloy with motor cut-off switch
Handlebar: steel comfort rise design
Stem: Promax alloy, adjustable angle
Grips: Velo dual density
Saddle: comfort design
Seatpost: Promax alloy suspension microadjust
Accessories: kickstand, rack
Requires one 24v10a battery pack (battery and charger included)
Assembly: adult assembly required
Dimensions: 68"L x 27"W x 46"H "
Descriptions vary on "speeds"
Not sure if 7 or 15 or 21
Walmarts "15 speeds" seems unlikely.
Picture seems to support 7 speeds, no front derailleur.
Walmart
Amazon
