Ebikker said:
I need some advise on finding the right rear hub kit for my mongoose hitch fat bike.I'm looking for a rear hub that will be at least as powerful as a bbshd.
then you will need to state the specific usage scenarios you have, because the bbshd can use your bike's gearing to make it appropriately powerful for whatever terrain or speed you need at the time. to do the same thing with a hubmotor you may need a much more powerful one, depending on the conditions you ride in (hills, wind, road type, etc), and your specific needs under those conditions.
provide as much detail as possible and it will help us help you figure out what you need.
alternately you can go to the http://ebikes.ca/tools/simulator.html and read the entire page to learn how it works, then put in your various conditions and try different setups to see which one best suits your needs. it's a useful tool to determine stuff like this, but there is a definite learning curve.
My riding conditions are all over the place because I ride in the sand,snow and road my speeds are on average 15 to 30. My biggest hills are the sky bridges in area.
I already have a 52v 13.5 battery that I would like to switch between the two bikes for now, but if i have to get a higher voltage or higher amp rating I will.
this depends on what your battery can actually do. does it have a rating for how many amps it can output? i am guessing by "13.5" you mean 13.5 ah, or amp-hour, which is just it's capacity. if it doesn't state how many amps it can supply, i would recommend assuming it can only do about that many continouosly, and perhaps twice that for a few seconds at a time, to keep from stressing it out (it might be capable of much more).
if that's the case, it can support about a 700w motor (13.5a x 52v), and could run it for at most an hour at that rate before being empty. if it's more capable, then it can support a bigger motor, but at the higher rate would last less time.
The battery is 52 volt 13.5 amp hour
Is there a kit ready to buy or at least a fat tire rim laced on a motor.
Rear drop out width 190mm
high torque
regenerative braking
small display screen
4 inch wide rims
name brands if possible
controller???
what specifically do you mean by "high torque"? that is a very relative term, so if you can't provide a specific torque value, you'd need to provide examples of what exactly you need that torque to do for you, for us to help you find the appropriate motor, controller, and battery combination to do it.
By high toque i meant high number of winding turns.
note that needing regen eliminates all of the geared hubmotors, and requires direct drive, which will generally take more current for a longer time from the battery and controller to do the same work at lower speeds. is there a specific reason to have regen braking?
I was thinking less brake wear and a little battery charging.
qsmotor can probably do what you want, as a kit; they have a thread in the for sale section with links to their sales sites. the qs205 is a nice powerful motor but very heavy.
