Just a bit of an update on the trike.
Firstly, the changes I made to the trike front end worked really well, and I reckon it actually handles better with a narrower track. Certainly easier to move around!
I have been getting plenty of use of the trike, using it as a daily commuter.
I have had an issue with spokes, though, having broken 6!
I replaced these, and then broke another one!
The one thing I have been disappointed in, is the extra weight of the SLA batteries. 12 Kg is a lot of weight, for only 36v/10 AHr. Having to lift the rear of the trike to turn it around, was a real pain!
As I want the trike to have useful assist, as well as the being able to ride it around unassisted, I really need less weight.
Fortunately, the hub motor isn't too bad, the total weight being 6Kg, including rim and tyre.
So, I am now rethinking what I want out of the trike, and the assist system, and what my options are.
I could just replace the SLA with LiFePo4 to reduce the weight of the battery, but still considering the options there as well, but
either Yesa, or 'duct tape'.
The other option I am seriously considering, is removing my BB drive, 24v system from my MTB and using that on the trike. Yes, less power and speed, but also a lot less weight! And I will be making more use out of my current 24v LiFePo4 pack.
This is partly because I seem to be preferring the recumbent to the MTB, but that's another story!
This system will only add about 5 - 6 Kg's to the trike, and still give me usable assist.
A side benefit will be being able to go from the (limited) 7 speed cluster, to either an 8 or 9 speed, with a wider gear range.
Remember, I still want to be able to ride the trike without power.
At the moment, I have removed the hub motor and battery pack, and I am really enjoying the lower weight. I have been doing a lot of rides using the trike as originally intended! Yep, not as fast, definitely more exercise, but able to ride long distance without a severe weight penalty.
Don't think I wanna go back to lead!
