First build l Earthwing 37 l mono 6355 10s
Jedi
I've recently finished my first eboard build. Thank you to this forum for the inspiration, knowledge, and support. And thank you to the vendors who are making great products more attainable. I too got interested after seeing the boosted board, and even more interested after riding one. I knew I could build one.
Materials:
Earthwing Muirderer 37 kicktail
DIYES welded motor mount paris trucks
DIYES 6355 230kv motor
DIYES 12s 120A ESC
Enertion SPACE cell 10s3p battery
Psychotiller 17" low pro enclosure
Wiiceiver & Nyko Kama
83mm flywheels
So far I've only put about 40 miles on the board. I've experienced zero signal loss from the wiiceiver and used silicone to secure the connections. I did lose a couple motor mount screws during testing, have since used loctite. I made a thick, multi-layer, rubber gasket for the needed additional space in the enclosure, and to dampen vibrations.
Hi Jedi
Nice ride man, good clean build.
Hope you have a lot of fun with it.
Could you tell me what the thing weighs?
I made a belt cover for that DIYE motor mount. Just have to tap the 3 small holes with 4-40 or M3 thread.
http://www.thingiverse.com/thing:1316001
@weechumlee thanks for the support, it's not too light, probably close to 20 lbs.
@joop1987 awesome belt cover! I will be asking my buddy to 3d print that for me.
