hydro-one
Need a foolproof BMS . LIPO .eight turnigy packs 5s5ah for a total of 10ah 84v(max). Needs to be small. Dont need discharge protection (controller will) , just low voltage cell level alarm/pulldown. The Controller LVC will be set at 3.6v per cell (limits current).
Im thinking--- http://www.tppacks.com/search.asp hvc/lvc, (but thats 150$ and out of stock!, without balancing, or charging). but would provide all the plugs, and i could then put all the balance taps into a 25pin connector . The bulk charge(meanwell at 80v or so) relay could be switched off with the cell level HVC. The ebrake would be pulled during LVCevent .
This would work ok!!
For balance/charging im thinking of single cell chargers (20s). They would need to be isolated as I want to charge with all the cells in series. Could I use a Turnigy 3s charger, http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7637 link 7 of them together??. Would this charge all the cells to 4.2v? for 35$. not bad. How accurate will it be?? will it balance (probably not)?
One problem I see is I need a charger that goes to 4.10 for balancing because the hvc is set at 4.16, and the opto is shared with the lvc(trips brake). So if i charge to 4.2, it will trip the hvc on the board and he cant ride.
Any other chargers that will charge a 84v string of cells as single cell chargers to only 4.15v or 4.10(lilo i know)?
I may have seen a 4x6s but can it do it????
I want simplicity for the customer. no buttons, plugs, wires etc. bulk charge/fast charge during lots of use times , then later a slow topup balance charge through a single connector for cell equalizing (not very often required in my experiance)
Any thoughts on if this would work well? Any suitable single cell or multiple isolated chargers?
I dont think i need a full bms, mabye with lifepo4 but not with these turnigy lipo!!!
thanks in advance
mike
thanks in advance
mike
