Looking for a decent suspension fork....I am very "Thrifty" so cost does matter :lol: but I would like it to work reasonably well and I am willing to pay whatever it takes to get there.
The bike is a hardtail, Mongoose Terrex, steel framed, bike from Walmart that I turned into an electric Mt Bike. MAC rear hub motor and a 52v triangle battery in the frame all from EM3ev. The bike weighs 67 lbs and I weigh 200 lbs…what fork should I put on it?
Details:
A. Aggressive off road riding, no jumping.
B. Axle diameter is .371 inches or 9.42 mm and it clamps to the fork on both sides i.e. not a quick release.
C. Bike came with 27.5 x 52mm internal width rims and I plan to run a 27.5 x 3.00 Maxxis tire.
D. 1 1/8 Steerer…no taper.
E. Dropout/OLD = 100mm.
F. Axle to crown approximately 20 5/16 inches or 515mm.
The forks I have found are tapered, have 110 mm dropout/OLD, and most use a 15 mm thru axles. I could use washers to space from 100 mm to 110 mm but the taper and the thru axle are show stoppers.
Any recommendations or enlightenment would be appreciated.
Thank You
Details:
Thank You
