waynebergman
I have a theory about the 2004 Giant DH Team frame and wondering if others have found this to be true or know a bit more about the Giant frames than my self. Other years of this model may have the same issues.
I think Giant has made there swing arm assembly & drop outs offset from the center line of the bike. When I look at my Ringle hub and 12mm axle that came stock on my bike I noticed that there is no dishing on the wheel but yet it needs it to have the wheel sit centered on its axle stops. If it was to sit in a normal set of centered drop outs and swing arm the wheel would sit off center but in the Giant frame it sits just fine as the drop outs seem to be offset so you do not have to dish the wheel.
So if any modification are made to your Giant DH frame drop out area to accommodate the 10mm axles many of us are all putting on these bikes from our DD hub motors the wheel may will sit off center by a lot unless to take into account the drop outs are not centered on the center of the frame. The right side of the tire (drive side) will rub on the drive side chain stay if you are running a large dirt tire. This is the case for me so I am now running a smaller width tire till I sort out a solution. The HS3540 DD Hub has got such a large diameter flange coupled with a very narrow flange width it does not make it a good candidate for dishing the wheel enough to get me centered. Or at least I don’t think it’s a good idea. I hope others can chime in on this. I feel there should be some angle to the spokes coming out of the hub on the way to the rim or I will loose lateral stability in the wheel.
I think many who have chopped out the old drop outs in there frame and have used epoxy to set in the Doc style drop out solution will be able to center things as they go, and have probably with out realizing the offset built into the swing arm I am describing here made it work making sure things are lined up before final epoxy treatment.
I want to mention this to others that may be fabricating a drop out adaptor up to make there frames work with our standard 10mm style axle to keep this in mind. Don’t just use the old drop out locations as something to put a centered wheel in and think you will siting in the center of your drop outs. You need to come to the left side quite a bit like at least ¼” with your drop out placements or else dish the wheel more that what I think is a good idea for these crazy sized hub flanges we are dealing with.
At this point this is just a theory I have and look forward to others input here and again just a heads up for others traveling down this road and a place to sort out this issue as I see this Frame is a popular choice for e-bike fun………….wayne
