Hi All,
I have an Ancheer 26" E-bike. Just recently when using pedal assist, motor seems to kick in for 3-4 seconds, stops, runs 3-4 seconds, stops, runs 3-4 seconds...... and this continues. Throttle makes motor run 3-4 seconds then it stops and won't kick in again unless I nudge the wheel backwards a bit and then throttle will make it run 3-4 seconds again.
I read lots of info on here and followed troubleshooting and when I got to the 3 hall sensors there seems to be an issue with sensor 1.
Sensors 2 and 3 seem good and cycle from 5/0/5v but sensor 1 cycles from 5/4.2/5v
Is that a typical way a sensor could fail and could that cause the weird motor behaviour I'm seeing or could the controller or something else be contributing to the 5/4.2/5v reading? I can't see any obvious shorts or damage on the board and wiring continuity seems good. Don't think I would be able to replace the sensor, it looks pretty tricky to do so just wanted some opinions before spending on new hub or new controller etc.
PS - tried two batteries including one brand new and fully charged.
Thanks
Thanks
