El_Steak
I want to go with an 88v / 50amps setup for my bike. 10ah is enough, but I need to be able to carry the charger(s) on the bike. Headway cells are very tempting but I'm not sure which way to go with all the packs, BMS and charger possibilities. I came up with the 3 ideas listed below, can I get some comments/suggestions from the experts?
Idea 1:
Get a 48v 10ah pack (like the one YPedal got) and a 48 volts LifePo4 charger. Buy an additional 8 loose cells and 8 voltphreak single cell chargers.
Pros:
Cons:
Idea 2:
Build my own pack from scratch using the red plastic blocks, buss bars and the Goodrum / Fechter BMS
Pros:
Cons:
Idea 3:
Buy 2 x 36v10ah packs from evcomponents (the ones in a plastic or aluminum case) and 2 x 36v chargers.
Pros:
Cons:
Idea 1:
Pros:
- Can go anywhere between 58 and 88 volts depending on how many loose cells I use.
- With single-cell chargers, balancing becomes a non-issue on the loose cells
- Fairly easy to set up, no BMS to buy and wire
- If a cell goes bad, I can just discard/replace it
Cons:
- No discharge protection on the 8 cells, I would have to be very careful and use a conservative cut off voltage on my Cycle Analyst
- 1 x 48v charger plus 8 x 3.65v is a lot of charger to carry around (I have to recharge at work)
- Many things that can go wrong with the 8 small chargers
Idea 2:
Pros:
- Its fun
- I can configure the pack any way I want
Cons:
- A lot of work
- Many opportunities to screw up the BMS, cells, etc.
- I haven't found a cheap portable charger/power supply (2 amps is enough) that I can use to charge at 90v
- Maybe I can wire 2 36v chargers in series?
Idea 3:
Pros:
- No assembly required other than a series adapter
- Nice case
- 36 v chargers are cheap and easy to find
- BMS included
Cons:
- Packs are limited to 20amps discharge so I'd need to bypass the BMS for discharge and only use it for charge
- Again, need to monitor the pack closely and use a conservative cut off voltage on my Cycle Analyst
- The batteries in those packs are soldered not screwed together. Replacing a bad cell could be more trouble.
- I've never seen the inside of those packs so I don't know how thick the wires are, how good the connections are, etc.
