And well.. that kinda sucked.......
Quote EVC :
" Built in BMS with max continuous discharge of 60a Max cutoff discharge current 100A "
Well, this is an e-bikekit.com hub motor in a 20" wheel with a crystalyte 35 amp analogue controller, shunt soldered for 45~50 amps on the Cycle Analyst meter..
This BMS does not automatically reset, it requires disconecting the wires and reconnecting.. 1st overcurrent cutout i reset and checked the MaxA value on the CA and it says 36 amps.
I then used up 0.3ah more and managed to cut out on command at low speed ( less than 20 km/h ), if i ginger the throttle to 25+ i can slam the throttle and peak at 50 amps for a moment and then * bzzt.. cutout.
Next step.. solder up the shunt ! :|
