dnmun
1 PW
was the controller powered up by the batteries while you were charging when the chargers went out?
dnmun said:the 9C would do 28kph i thought on 36V. especially since your packs are so wide. is that an option?
dnmun said:seems like you just got covered in mosquitoes from the start. you,me, and everybody i know is having bad luck.
Cargo_Tom said:Controller update:
I have identified a mosfet short somewhere in the first bank of the damaged controller.....With any luck the mosfet fix will be enough. Time will tell
Chalo said:I suppose you already know this, but when the coaster arm breaks loose, it loosens the hub bearings. If you haven't checked the hub for free play, be sure to do so before you get back on the road.
Cargo_Tom said:Update: The bike is up and running again with a new controller. Yay.
(...misc. agony here... ) Apart from the totalled fender and coaster brake clamp the bike is fine.
Tomorrow I will be investing in a SS U-bolt to reattach the coaster brake torque arm to the frame.
learn, eh
Cargo_Tom said:As a bonus he services the mechanicals of the local Postal Service ebike fleet, including its 50 tadpole cargo ebikes. Apparently he has to rebuild their wheels frequently, as the standard rims and spokes are not up to the tasks of hauling hundreds of pounds of mail every single day. No such problems with the old long johns, as they use moped spec wheels and drivetrain components.
Just want to ditto this! There's a compromise between speed & torque, as you well know. I went for the latter to get my fat ass up hills in my locality. After considering the options, I got the 500 watt Heinzmann hub, because its geared and could provide the torque. It was the right choice. For your situation, I'd recommend more like a 1000 watt geared motor. Bestkmxtornado said:CONCLUSION:
I would recommend an IGH for most applications, but it's definitely not for everyone. If you're a downhill racer on a carbon fiber road bike, that extra 3lbs amounts to a lot! However, it's perfect for folks like you who are already hauling weight and hill climbing is already difficult.
May be I missed it. What is the problem that reappeared? Every cells is resting at 3.305v?Cargo_Tom said:No dice, so ordered a replacement BMS from ping. After replacing the BMS I was able to recharge ONCE before the problem reappeared :/ Every cell is resting at 3.305v +/- 0.003v atm.
SamTexas said:May be I missed it. What is the problem that reappeared? Every cells is resting at 3.305v?
