crossbreak
IMO 52T is the largest chainring that still looks OK.I want to figure out the different possible MEGA overdrive systems that can be used in a high speed non-hubmotor drive.
The 21.5" wheel is a 16"-2.75" moped wheel with 21.5" outer dia
#1: Sturmey Archer S80 XRK8 8-Speed Disc Brake Hub
Overdrive: 3.25
Smallest sprocket i have found: 23T
Over all overdrive: 52/23 x 3.25 = 7.35
Spread: 325%
Price: around $150
Speeds at 85rpm crank speed: 28"->84km/h 26"->78km/h 24"->72km/h 21.5"->64km/h
Speeds at 85rpm crank speed: 28"->52mph 26"->48mph 24"->45mph 21.5"->40mph
Homepage: http://www.sturmey-archer.com/products/hubs/cid/5/id/9
#2: Hammerschmidt/Schlumpf/Metropolis-Patterson Drive with chain wheel adapter and 11-32T derailleur
Overdrive: 1.6
Smallest sprocket: 11T
Over all overdrive: 52/11 x 1.6 = 7.56
Spread: 465 %
Speeds at 85rpm crank speed: 28"->86km/h 26"->80km/h 24"->74km/h 21.5"->66km/h
Speeds at 85rpm crank speed: 28"->54mph 26"->50mph 24"->46mph 21.5"->41mph
Price: from $200 (Metropolis-Patterson) to $400 (Hammerschmidt) to $600 (Schlumpf) plus chainwheel adapter and derailleur. The Schlumpf does not need a chain wheel adapter, it is directly compatible to 52T chain wheels. The Hammerschmidt can take 130mm 5-arm chain rings using my adapter: http://www.endless-sphere.com/forums/viewtopic.php?f=31&t=58436
For the Metropolis-Patterson there is a 5-arm adapter available from the manufacturer.
Schlumpf: http://www.haberstock-mobility.com/en/products/schlumpf-drive.html
Hammerschmidt: http://www.sram.com/truvativ/products/truvativ-hammerschmidt-am-crankset
Metropolis Patterson: http://www.metropoliscomponents.com/patterson.htm
#3: Schlumpf High Speed Drive with 11-32T derailleur
Overdrive: 2.5
Over all overdrive: 52/11 x 2.5 = 11.8
Spread: 727 %
Speeds at 85rpm crank speed: 28"->134km/h 26"->125km/h 24"->115km/h 21.5"->103km/h
Speeds at 85rpm crank speed: 28"->84mph 26"->78mph 24"->72mph 21.5"->64mph
Price: ???
With ratios below 7:
#4: Shimano Alfine 11-Speed Hub SG-S700
Overdrive: 2.153
Smallest sprocket i have found: 18T
Over all overdrive: 52/18 x 2.153 = 6.22
Speeds at 85rpm crank speed: 28"->71km/h 26"->62km/h 24"->61km/h 21.5"->54 km/h
Speeds at 85rpm crank speed: 28"->44mph 26"->41mp h 24"->38mph 21.5"->34 mph
Spread: 409 %
Price: around $400
Homepage: http://bike.shimano.com/publish/content/global_cycle/en/us/index/products/0/alfine/product.-code-SG-S700.-type-.html
#5: Rohloff Speedhub 500/14
Overdrive: 1.467
Smallest sprocket: 13T
Over all overdrive: 52/13 x 1.467 = 5.87
Spread: 526%
Speeds at 85rpm crank speed: 28"->67km/h 26"->62km/h 24"->57km/h 21.5"->51km/h
Speeds at 85rpm crank speed: 28"->42mph 26"->39mph 24"->36mph 21.5"->32mph
Price: ???
Homepage: http://www.rohloff.de/en/technology/speedhub/technics/index.html
#6: 52T with 11-32T derailleur
Overdrive: 52/11 = 4.73
Spread: 291%
Speeds at 85rpm crank speed: 28"->54km/h; 26"->50km/h; 24"->46km/h; 21.5"->41km/h
Speeds at 85rpm crank speed: 28"->33 mph; 26"->31 mph; 24"->29 mph; 21.5"->26 mph
Any more options for overdrive ratios >7?
Overdrive: 3.25
Spread: 325%
Price: around $150
Overdrive: 1.6
Spread: 465 %
Overdrive: 2.5
Spread: 727 %
Price: ???
Overdrive: 2.153
Spread: 409 %
Price: around $400
Overdrive: 1.467
Spread: 526%
Price: ???
Spread: 291%
