"Stuck" is how these old style cranks stay on. Do you not have a standard square taper crank puller? Use a cheater pipe on the handle if you need more torque.
Simply remove the bolt in the crank arm using a spanner. This tool requires a 16mm(5/8) or adjustable spanner for use. 1 x Universal Bike Crank Puller Tool. The Crank Removal Tool makes removing the crank from your bike quick and easy.
