I have a 800 watt rear 36volt yescom motor (2s2p 5000mah 6 cell Turnigy packs) with a Lyen 9 4110 fet controller and I noticed when braking with regen (on the mildest setting) I get a clunk noise. This only happens the first time I brake after having power on.
The axle is tight and the fit on the 2 -1/8" stainless torque plates seems snug. I have even tried marking the parts to see if there is movement, and there seems to be none.
Is there anything internally I should be worried is getting loose? Or any good way to check for miniscule axle rotation?
Thanks, Alex
Thanks, Alex
