mwkeefer
Hello All,
Although far from my intended final design (using HV110 & MS eDrive 2Stage + Tower Pro 5330-9T), because Matt has been so busy with the eDrives lately (I didn't want to add one more order to his load) I had to either back burner testing and development of my pre-controller (combination systems monitor, step up/down buck converter, current limiter, cruise control, variable - cell level LVC, etc) for a month or two or purchase a hub motor and start testing, logging and debugging my code / design.
I suppose the subject makes this overly obvious but I obtained a 26" 36v 500W front hub kit from Jason @ http://www.e-bikekit.com just so I could get my eBike up and running (for above reason and a few others).
What I have learned about these kits, the hub motors and the 9FET infineon controllers could fill a small book (or with my posting style perhaps a large book) but I wanted to give anyone thinking of using this kit as a starting point or even a final eBike the benefit of my testing and experimentation.
1.) Forget 500W rating, far under-rated! I have personally acheived > 2000 W sustained output by opening up the programming on the Infineon controller, raising the Rated Current to 38.5A and the Phase Current to 75A. I have tested using 36S3P 9.9AH nimh pack and a 12S 5AH Turnigy Lipo Pack (Build of 4x3S in Series) with the lipo getting better results for all out accelleration from stop or low speed. The nimh pack clearly had better range but at near 10AH rated capacity, that is no wonder.
2.) Forget 36v rating. Even the Lifepo4 batts offered by Jason at http://www.e-bikekits.com are 12S config or 46.2v off the charger, so a 12S lipo pack @ 50.4 off the charger (@ 4.20v per cell) is fine. I haven't tested with 15S yet as I am working on a soft powerup circuit to prevent arcing when batteries are first connected but 63v off charger should be the MAX V (based on 63v FETs). The 15S will likely blow the FETS but so far the only Voltage I am sure will toast the 9 FET ESC is 72V > (tested and confirmed to smoke controller).
3a.) When using your own battery option with this controller and hub, you will want to use Parameter Designer (http://endless-sphere.com/forums/viewtopic.php?f=2&t=5713&start=180#p163592) to configure a safe Low Voltage Cutout, Rated Current and Phase Current. I have not gone above 40/75A which gave me > 2000W peak without even warming the motor to the touch under load (or the batteries for that matter).
3b.) You should also know, the small red or orange wire from the controller to the batteries is actually a on/off lead and as such can be run through a normal SPST switch to turn the controller active/inactive. This is important because the current draw in off mode (wire disconnected) is 10ma while the draw with wire to power source is 700-800ma minimum. When your not riding (parked, at work, whatever) turn the power switch off to avoid draining more power from your batteries than you need. This reduces the draw to a bare minimum without needing to disconnect / reconnect the main power leads and deal with an arc (working on this)
4.) These controllers need airflow!!! - Even without modifications or changes to current limiting this controller needs airflow or it will burn up. I am lucky to have an extensive logging / monitoring system in place so I quickly noticed the ESC approaching 150F and remounted it under my front mounted handle bar bag. I used hobby pine to make a reinforcement panel that goes inside the bag (with a hold cut out to pass wiring through) then I just screw the controller upsiide down to the bottom of my bag and run the harness through the hole I pre-drilled in the wood panel. Bottom mounting the controller puts it in the airflow and the heatsink does it's job (mount with sink screws facing forward) max temp with this mounting position was steady 128F while running 1/2 throttle @ 16-18mph up a 20+ grade just under a mile long.Controller returned to < 118F within 10 seconds of completing the climb and reaching level ground. Within 15 seconds controller was < 100 degrees stable. I also ran the same test but at WOT without pedaling and as expected the temp stayed lower (presumably becaue at WOT the FETs were 100% on and switching only to limit max current which seems to generate less heat than partial throttle settings. Maybe a fan fould keep the temps lower when under load with partial throttle, I will test when I have a chance.
There are many more "tips and tricks" things to be revealed about thhese e-bikekit.com hubs and 9fet controllers which I will post later as time permits, up next: How I managed to install front hub on same Specialized Hard Rock Pro (Disc) that Jason tried and broke the drop outs. Including my el-cheapo torque arm solutions using off the shelf (ACE hardware) parts or 10MM bicycle brake wrenches. They are not pretty yet but they do save my front forks (recently upgraded to full lockout capable) and they have stopped all spin on the axle within the dropout even under the heavy torque of my modified controller programming (and a few other tweaks).
Hope this helps someone!
- Mike
- Mike
