MR30
100 µW
Hi I have been lurking this site for about a month, decided to buy this kit
http://www.ebay.com/itm/291119531800?var=590270751128&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 from eBay seller xcceries and have had nothing but problems. Do you guys think the motor is blown ? Is this something I can fix myself or will I have to send it back. Seller hasn't been very helpful so far and return shipping will be a hassle and will cost an arm and a leg. Here's a copy and paste of my conversation with the seller.
This was his reply
I don't even think that he\they are reading my emails. I sent him a few pictures already and am hesitant to put it all back together just to take more pics. It was a PITA to take pics and use the multimeter. I would appreciate any help you guys have to offer.
Ebay would not let me attach pictures so I had to link them. I have disassembled the kit because I use the bike. As you can see my battery is charged to 38.6 V, the throttle led shows it as fully charged but nothing happens when I hit turn the throttle. I have double and triple checked all the connections several times and am 100% sure it is installed correctly.
This is what I am seeing on the throttle. It has 3 harnesses.1st harness has 3 wires, red, green and blue on the throttle side and red, white and black on the controller side. I don’t see any power when it is off and I see 4.39 V on the red wire when it is on. I see 0.80 V on the green=> white wire when the throttle is not turned and up to 3.62 V when it is twisted all the way. 2nd harness has 2 wires, brown and yellow and I don’t see any power when it is turned off and around 38V when it is turned on. 3rd harness also has 2 wires, also green and brown and I don’t see any power when it is turned off and around 36-37V when it is turned on. There are 3 thick (12 or 14 awg) single wires going from the controller to the motor. These wires are green, yellow and blue. I don’t see any power when the unit is off on these wires and I see 9.7 V on the green and yellow wires when I twist the throttle to all the way. I think the blue wire is a ground.
There is a 5 wire connector going from the controller to the motor. I think this is the hal sensor connectors. I see 4.2 V on the red wire and 4.9V on the green wire when I connect my multimeter all the other wires are off. Based on what I have done so far I am pretty sure that the motor is toast but am willing to try any troubleshooting steps you might have. If you agree that it is broken, I would like to return it for a refund if you cover the return shipping charges.
This was his reply
Dear Customer, Thank you for getting back to us with the words in details. As we need to report this problem to our supplier and figure out the exact problem, could you please kindly send us a short vedio showing the test so that we can be more clear? You can send the vedio to xcceries at yescomusa dot com with your eBay id. By the way, is the light on the throttle works? Is your battery charged full in use? Look forward to hearing from you soon. Any questions, please feel free to contact us and we will promptly assist you.
