KLS identification angle operation
fany
Here is the correct operation steps for identification angle function.
It is for 8080I/IPS controller.
1,Please connect 12V-24V to pin7 and pin6.Pin7 is positive and pin6 is GND.
pin7 and pin6 is the isolated power supply for KLS-8080I/IPS controller.
2,Please connect the motor phase cables to U,V,W.Please connect hall sensors connector to the controller.
3,Please connect the batteries to B+ and B- of the controller.
4,Please connect the throttle wires to the motor controller.
5,Please connect the USB cable and 4pin connector to RS232 converter between controller and user program.
6,Please double click the KLS user program.
7,You will see the first picture of user program.
8,Please read the identification angle value.It is good if it is at 85.
9,Please fill 170 in the identification angle item.And please click the write button.Please turn off the power supply.
10,Please turn on the power supply after the power supply is off for a few seconds.The controller will send a constant beep sound.If you get a KLS-S controller,the LED will be solid on in this case.
11,Please wait about 2-3 minters.
12,If the identification is finished,the constant beep sound or solid Red LED will be disappeared.And you will see reset error in the monitor screen.
13,Please turn off the power supply again.Please wait about a few seconds to turn on the power supply again.
14,You will see 85 in the identification angle item.That is to say,the controller identification angle operation is successful.You can use the controller to drive the motor now.
15,If the constant beep sound last above 5 minters,please return the first picture of user program.Please write 85 instead by manual.
Please don't keep 170 in the identification angle item in this case.
And please turn off the power supply in this case.
Please try again from step 6.
16,Please don't keep 170 in identification angle item before power supply is turned on after the identification operation is successful.
It is for KLS-S/D controller.
1,Please connect Battery Voltage for pin7 and B+/B-.
crossbreak said:
Minters == winters ? I dont want to wait 5 years for an answer :0 winters== minutes?
Sorry,it is type mistake.
My fault.
I meant 2-3 minutes
