larsb
It's nice to see that at least someone is using their e-grins :thumb:
This can and will be hacked. But I wouldn't expect more than 650-675A (it's still 30 fets in to220). There's one more downside of em200, temp coeff's can't be changed...j bjork said:It seems like the em200 only does 570pA vs em150sp:s 540pA, so not much of an upgrade.
It's confirmed, ASI BAC doesn't have MTPA implemented, which means all kinds of ipm motors will perform underpowered (qs138*, me1616, 1507 included iirc). This may change in the future though.Asi Bac 8000 delivers the amps, but dosent seem to have anything like MTPA
And this is when you're putting the rig on a dyno, the dyno, your dyno... werent you building one? Anyway unfortunately the id lookup table of apt96600 didnt seem to work when I tried it last time.larsb said:The APT9660 has detailed flux weakening setting so if you have a dyno it could be halfway decently mapped to MTPA.
j bjork said:I think it is odd, there are motors available. But no controllers :?
And qs seems to have their 180 90h motor more or less finished (maybe, who knows?), but dont seem to release it as they dont have a controller for it. They dont seem to sell it without controller either though, so I wonder how finished it really is.
I think they should wire it for 6 poles, and use 2 em150sp:s
larsb said:Yeah, i lost interest a bit. Too many projects at home and too much pressure at work and now the efoil fun took over.. it’d help if i had a controller that could be mapped without too much hassle.
thoroughbred said:I was thinking that those motors have two separate stators, each 3 phase that you could hook separate controllers onto. Arlo might have done 2 controllers with a Zero motor, which i think is the same design, albeit waterproof. obviously, my understanding is lacking here
larsb said:@j bjork: That is true but the problem is that APT96600 is only semi-functional chinese crap.
I think it might work in the OEM chinese version and then it’s destroyed by the restrictions programmed before sold to us commoners. At least that’s what would make the varying/faulty functionality understandable.
j bjork said:They are not just difficult, they are big too.
305x170
116v max, so up to 28s if charged to 4,14v max.
660pA peak for 10 sec.
