- Joined
- Oct 18, 2017
- Messages
- 12
I'm in the market for ultracaps. Those Skels look good but they come in 10 packs and are weld only. I would need another welder to weld the ultracaps for my welder.
The "4800mAh 2-Cell/2S 7.4V Reaper 120C LiPo, Shorty" sounds really promising, they state 1152A max burst discharge. But can someone tell them that Deans/EC3/EC5/Traxxas/XT60 connectors are all hopelessly underrated for a battery that is rated for 576A continuous?The Lightning Stalker said:I don't know if these are new or if I just didn't notice them, but Thunder Power has some 120C stuff right now.
http://www.thunderpowerrc.com/CAR_BATTERIES/Reaper
The specs on these are getting pretty insane now.
Are there any plans for pulse arc capabilities on the kWeld? Of course it would need the proper solenoid tungsten holder. I'm thinking it could be useful for welding ultracaps etc.
I want to make pulse arc welding experiments with kWeld, as I think that this is well in reach. Maybe it just needs a higher battery voltage.fechter said:Pulse arc is interesting. I did some experiments using a non-contact electrode and high voltage starter. I've never tried using a solenoid but it might work.
I actually sell them: www.keenlab.deandrew.box said:Wow, nice project. If you end up selling boards or kits please say so here. I bet we could get a number of people who'd reserve a board and parts. Also try the DIY power wall forums, those folks love spot welders.
okashira said:I just ordered one for some testing.
How soon will it ship?
What a monster! :wink:bigbore said:This is what Kweld looks like with 4AWG cables
That'll probably depends most on your battery, I forgot what type you plan to use? The welder itself accounts for 0.33mOhm (switch path) + 0.78mOhm (fuse path) from terminal to terminal (actual measurement data).bigbore said:I’m very excited to find out what resistance I have after calibration. The length of the cables are the same as per manual with shorter electrodes holders
Keep in mind that this also adds inductance, and to dial the total round trip length into the unit if you exceed EDIT: 1 meter.bigbore said:but with this bigger wires I guess I can make them longer.
tatus1969 said:That'll probably depends most on your battery, I forgot what type you plan to use? The welder itself accounts for 0.33mOhm (switch path) + 0.78mOhm (fuse path) from terminal to terminal (actual measurement data).bigbore said:I’m very excited to find out what resistance I have after calibration. The length of the cables are the same as per manual with shorter electrodes holders
That looks like it has very low ESR, together with your thick wires you may exceed the 2kA limit. You'll see during calibration, maybe you need to reduce to 2S. Just guessing, anyway.bigbore said:I will be using a 3S5P lipo made with very old zippy lipo 5000mAh 40C cells; this one
No, calibration only measures between the two output terminals of the module, that is Rc3+Rc4. But as Rc1/Rc2 should be extremely low in your case, you can estimate the battery ESR from the current that is displayed, and the other known values.bigbore said:Then from calibration il will get Ri+Rc1+Rc2+Rc3+Rc4+Rs. Is it correct?
It is 0.4m each for both electrode wires, and 0.1m each for the battery wires. The total is 1.0m, not including the lengths through the module, those of the electrode holders and electrodes, and of the wires on the Lipo itself. I wasn't too accurate here, but there is quite some safety margin.bigbore said:Also could you tell me the total length of both electrode cables you obtain with your electrode holders? I would like to know the length from electrode tip to the center of the ring cable shoe hole.
bigbore said:As a LiPo alternative I would like to try a 4S4P made of LifePo4 A123 26650 like these:
http://www.batteryspace.com/A123-System-Nanophosphate-LiFePO4-26650-Rechargeable-Cell-3.2V-2500-mAh.aspx
It's not about the inductive kickback, that only depends on flowing current and conductor inductance (inductance is a pure geometrical/material relation). The reasons why I try to keep the battery (or ultracapacitor) voltage as low as possible are this:spinningmagnets said:Frank has mentioned that lower voltages might be slightly better (smaller inductance spikes?)
spinningmagnets said:It's starting to look like the 12V car starter lead-acid battery truly is the best option for someone who does not want to use LiPo.
The 12V style is everywhere, but I recall there are 6V lead-acid starter batteries for older cars and golf carts (perhaps rare, and hard to find though...)
