I'm at the stage of my build where I am trying to build the front wheel. I've bought an 18" rim and a Vector hub (room for 2 discs https://vectorebike.com/bike/other/disc-front-hub).Once they arrived I took some measurements and have settled on 193mm spokes after deciding on doing a 2 cross lacing pattern. I've looked at a few tutorials about both mountain bike and motorbike lacing but as this is a combo of the two, none of them seem to be working. I am able to get all the spokes that go from the outside of the hub to the inside of the hub secured and with lots of wiggle room for adjustment. However once I start adding the spokes that cross in the middle, it pulls to one side so the first set are very easy to put in and have no tension but the other side require a lot of manoeuvring and are noticeably bent when the nipples are attached. Once the first set is in, I can't move the hub over so I'm guessing I need to keep the hub in the centre during each stage of the build and do each side one spoke at a time rather than going the whole of one side and then the whole of the other?
