That integrated pre charge/ disconnect is a nice solution. I think as you say I should try to build in as much headroom as I can sensibly into the system wherever there is a component choice that will allow that.
I am incorporating a switch, just to provide the option for swapping batteries, or away from vehicle charging. The pack size I can incorporate is not huge in terms of parallel groups due to packaging into the existing space, so the overall capacity is limited, approx max 3.6kwh so it would be helpful to have that option.
I’ve been looking for a bolt in fuse somewhere around 100 to 110vdc, I have found a motor home battery disconnect with a claimed rating to handle 300 Amps it is ip65 so that is a bonus although none of these components will be exposed to the weather and a 30w Vishay relay from Mouser.
The spec sheet for the BMS 20s 20p model states a continuous 200A and peak 350A rating so the fuse perhaps should rate at or slightly below 200A? Unfortunately there isn’t any detail that I can see the gauge of the built in cables but my plan was to use both B- and P- cables to carry current from the pack to the controller and to splice off a separate connection to the charger and to do the same for the + from the battery.
Thanks again this is really helpful.
