Thanks! you are so kindAddy said:Thanks for sharing all your pictures! Your bike is really interesting. With all that cargo and water capacity you can go on quite a journey.
matmaxgeds said:do you know how much it will cost?
matmaxgeds said:I think I found it here - bottom right: https://en.activa-ht.com/%E5%89%AF%E6%9C%AC-eu-3-0-plus - do you know how much it will cost?
Chalo said:matmaxgeds said:do you know how much it will cost?
I do!
More than a two wheeler that does the same thing.
One of the main goals of engineering is to meet the project's requirements with a minimum outlay of money and resources. So the question is, what is the requirement here? I suspect the purpose was specifically to use three wheels to do the job of two.
matmaxgeds said:Chalo said:matmaxgeds said:do you know how much it will cost?
I do!
amusing.......unicycles for the win then!
Chalo said:So what's the advantage over a two wheeled cargo bike, to justify the extra expense, weight, inefficiency?
Somewhat like this I did before, but do you need the trike tilting?matmaxgeds said:For me the main use is for heavy loads
