goatman
got this battery for testing
heres a link for how to spot a fake HG2
https://batterybro.com/blogs/18650-wholesale-battery-reviews/104619270-can-you-identify-the-fake-lg-hg2-18650-battery
the can has absolutely no identifiers on it
insulator ring is textured on one side, you can see a bit of "shine" in between 12 and 1 o-clock but?
weld marks are different than in the article
maybe its part of the 2016 batch mentioned in how to spot a fake
interupted my 30q test, dont mind the graph title
charged to 4.2v
battery held at 4.191v after 2 minutes :thumb: start 10amp discharge
stopped discharge at 3.2v, battery temp reached 128f/53.3 celsius
curve looks good, mah is about right, actually it should be around 1900/2000mah at 3.2v from the data sheet
https://www.nkon.nl/sk/k/hg2.pdf
ill get another hg2 tomorrow to compare
ill do a 5amp discharge to 2.5v and compare to this chart
heres the 5amp discharge 2585mah, peak temp 110f
if you compare to this sites handy comparison charts, you can change discharge rates see curves and compare 2 batteries on same chart, i dont know what this battery is
https://lygte-info.dk/review/batteries2012/Common18650comparator.php
charged to 4.2v
