Hello,
I have a problem with my battery pack (all stuff from BMS Battery)
Specs:
Headway 40152S 15Ah 10C LiFePO4 Cylindrical
Battery Cell
16S LiFePO4 BMS - Battery Management
System - Discharge Current : 50-100A
Alloy Shell 900W LiFePo4/Li-Ion/Lead Acid
Battery EV Charger - AC Voltage : 200V~264V
Battery Type: : Headway 40152S 15Ah
10C LiFePO4 Cylindrical Battery Cell
Calls in Series: : 16
AC Plug Type: : Prise mâle de type E/F
(norme CEE 7/7)
DC Connector Type: : T-Shape Brass
Connector
Charge Voltage (Default: Typical value
):: 57.6 Volts
Charge Current (Default: Maximum)::
11.52 Ampères
I suspect that the battery is not fully load,and for the vendor all is ok and I don't have to take care about these disparate voltages.
Does someone could help me, please ?
the problem explain
Hi Jack,
here is the results below, and the pictures are attached:
Before charging battery
total voltage = 52.5 Volts
cell 1 = 3.29 Volts (+)
cell 2 = 3.28
cell 3 = 3.29
cell 4 = 3.28
cell 5 = 3.29
cell 6 = 3.28
cell 7 = 3.29
cell 8 = 3.29
cell 9 = 3.29
cell 10 = 3.30
cell 11 = 3.29
cell 12 = 3.29
cell 13 = 3.29
cell 14 = 3.29
cell 15 = 3.29
cell 16 = 3.30 (-)
Charging process during time = 35 minutes
Voltage during charge 55.4 Volts
First time I hear the charger fan rotating.
the bms was very hot (PCB side) especialy near the white connectors .
the brushed aluminum face wasn 't hot.
After charging battery:
total voltage = 57.4 Volts
cell 1 = 3.42 Volts (+)
cell 2 = 3.58
cell 3 = 3.71
cell 4 = 3.63
cell 5 = 3.66
cell 6 = 3.67
cell 7 = 3.60
cell 8 = 3.68
cell 9 = 3.65
cell 10 = 3.65
cell 11 = 3.67
cell 12 = 3.37
cell 13 = 3.38
cell 14 = 3.42
cell 15 = 3.66
cell 16 = 3.70 (-)
In order to not damaged cells , I unloaded a little battery with the motor and the voltage is very quickly came to 53.7 volts.
Is that a cell that has increased to more than 3.6 Volt is deteriorated ?
It looks like the bms does not play its regulatory role during charge and that it allows a cell to be charged beyond the upper limit.
What do you propose for the future?
if somebody could give me an advice, or an opinion, it would be great friendly !!
I was planning to open a paypal dispute and return back all the stuff to the supplier, but if I can make an arrangement, why not !
See you later
Specs:
Battery Cell
(norme CEE 7/7)
Connector
):: 57.6 Volts
11.52 Ampères
the problem explain
Hi Jack,
cell 2 = 3.28
cell 3 = 3.29
cell 4 = 3.28
cell 5 = 3.29
cell 6 = 3.28
cell 7 = 3.29
cell 8 = 3.29
cell 9 = 3.29
cell 10 = 3.30
cell 11 = 3.29
cell 12 = 3.29
cell 13 = 3.29
cell 14 = 3.29
cell 15 = 3.29
cell 16 = 3.30 (-)
cell 2 = 3.58
cell 3 = 3.71
cell 4 = 3.63
cell 5 = 3.66
cell 6 = 3.67
cell 7 = 3.60
cell 8 = 3.68
cell 9 = 3.65
cell 10 = 3.65
cell 11 = 3.67
cell 12 = 3.37
cell 13 = 3.38
cell 14 = 3.42
cell 15 = 3.66
cell 16 = 3.70 (-)
See you later
