Pilot Engineer said:
Yes, please find here all the available versions:
Matteo, this looks very good, at least on paper. I especially like that the motor keeps a decent q-factor. The Bafangs and Tongsheng motors are hurting my knees.
After giving this a thorough google-fu session, I still have some questions:
*Which bottom brackets may I use? External Shimano cups? Can I freely chose between square taper or ISIS mount? Do all variants only add 3 mm of pedal stance to one side and can I use a BB shim to correct that?
*At what pedal cadence does the motor give out? I understand it depends on the cog and battery voltage. Let's say the 1000W version with a 52V battery and 12t cog; can I keep 100 rpm and still have the motor pull a good force?
*Concerning pedals and chain wheel guard: are all compatible? (I expect to order custom pedals from Miranda or similar.)
*There's no update on Indiegogo. Guestimate has been delivery in october, does that still hold?
*Are other displays compatible? Reason is, the SW102 and Eggrider are not ideal for drop bars, due to the lack of a remote that can be fitted closer to the hoods. Any way to order just the motor and use one of the displays I already own? I even have two SW102 already, not that I use them on the drop bar tourer.
Good luck with your project, Matteo! I hope this turns out a success!
/Björn
